OK, I know what the problem is, and I think I know what the solution is, but I dont know how do solve it.
The problem is that I just installed my eurolights with a new dimensions harness. My city lights and low beams work fine, but I get only city lights when I switch to high beams. The new dimensions harness has two relays, one for lows, and one for highs. I tapped into the low and high beam wires on the drivers side first and the highs didn't work. So I ran a jumper from the battery to the relay to trigger the high beams and they work fine. Then I ran a jumper from the passenger side high beam to the relay and they worked for a few minutes but suddenly blew the fuse for the high beams.
Upon further inspection I found that both highbeam fuses were blown so I assume that the reason that the highs weren't working before was because of a blown fuse. So there is the solution, there is a problem with a short somewhere causing the high beams to blow their fuse when they are triggering the relay. I have inspected the whole wiring harness and nothing appears to be wrong. Does anyone have any ideas?
I know that there isn't really anything you guys can do, it seems like the answer is right there in front of me but I just am not seeing it, but I was just wondering if anyone had this problem before?
