1 - 10 of 10 Posts
Has anyone figured out the coding to use the turnsignals as parklights when parked on dark side streets?
Looked in MKVI threads but no luck and yes am coded to GB option,euro switch etc..
I'm pretty sure that this is controlled by Byte 18, at least that is what I've been told.
If you have a vagcom, contact Ross-Tech and they should be able to help you.
Discussion Starter · #6 ·
Yes I do have one and I use it daily because of work,you have a point about byte 18 as I was focusing on LED tails mainly.
Thanks.
1 - 10 of 10 Posts
