1 - 20 of 20 Posts
Ok boys and girls, here's the data. All runs were 3rd gear. K&N was run a few nights ago at 39F ambient and dry air, EVO CAI was run a little while ago at 37F ambient and higher humidity...it snowed early this morning. I don't consider these temp/humidity changes significant, and the runs were done on the same stretch of road after an identical warmup from cold start.
For those who just want the quick version, if you take the K&N values at the RPMs that match (or are only 40 revs apart) the CAI has a small edge down low (probably the turbo spools a little quicker, maybe just BS). At about 5500-5800 rpm, you start to see the CAI pull away if you graph it. At 6240 you'll notice that the CAI has its peak difference of about 10 ft-lb and 12 hp. Finally, despite my mediocre midrange torque numbers, I hit 230hp at 6800 rpm.
http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif I also noticed that the VAG-COM torque hit almost 300Nm in 4th and 5th, whereas the K&N would not budge past 285 no matter what I did.
Pretty Picture:
http://photos.yahoo.com/bc/dbrowne1978/vwp?.dir=/VW&.dnm=VW+Dyno1.gif&.srch&.view=t
DATA:
K&N
ft-lb hp RPM
0:00:00 0 1680
21.6972 7.601456207 1840
105.6078 35.3902757 1760
122.9508 43.07491851 1840
138.8916 51.83311805 1960
157.6368 62.43041584 2080
163.467 69.71936024 2240
177.9318 81.30927647 2400
179.334 87.41337395 2560
189.5184 99.59458949 2760
179.334 101.0717136 2960
183.6882 109.121703 3120
202.5072 128.0129292 3320
209.7396 138.9744494 3480
206.8614 144.9447738 3680
205.3854 150.167543 3840
205.3854 157.9887692 4040
202.5072 161.944067 4200
202.5072 168.1133648 4360
199.629 171.8056131 4520
196.7508 175.322495 4680
195.2748 179.9562133 4840
193.7988 183.024 4960
192.3966 187.5610419 5120
190.9206 190.4843762 5240
189.5184 194.8589794 5400
188.0424 197.6378614 5520
183.6882 197.2584631 5640
180.81 198.2988576 5760
179.334 200.7775933 5880
176.4558 201.5869764 6000
173.5776 202.2648347 6120
176.4558 208.3065423 6200
173.5776 207.5528043 6280
173.5776 211.5187814 6400
173.5776 214.1627662 6480
173.5776 216.806751 6560
EVO CAI
ft-lb hp RPM
0:00:00 0 1480
73.8 21.35872049 1520
108.486 32.22356436 1560
121.4748 37.93196344 1640
131.6592 43.11763595 1720
143.172 50.15926885 1840
163.467 61.00444021 1960
161.991 64.15485149 2080
183.6882 79.74278294 2280
179.334 83.31587205 2440
185.1642 93.07568317 2640
192.3966 104.0377654 2840
201.0312 116.3623092 3040
195.2748 120.466556 3240
208.2636 134.8241127 3400
208.2636 141.1687768 3560
205.3854 147.0390526 3760
205.3854 154.8602788 3960
203.9832 160.0172856 4120
202.5072 166.5710404 4320
199.629 170.2852094 4480
196.7508 173.8240122 4640
196.7508 179.8179436 4800
196.7508 185.8118751 4960
195.2748 188.8796618 5080
193.7988 193.356 5240
190.9206 196.3006931 5400
190.9206 200.6629307 5520
186.5664 201.7702117 5680
185.1642 204.4844554 5800
185.1642 208.7151683 5920
182.286 209.6358416 6040
179.334 210.3384311 6160
183.6882 218.2434059 6240
182.286 220.7423762 6360
179.334 221.2651028 6480
180.81 225.8403656 6560
179.334 226.7284387 6640
179.334 229.4601066 6720
177.9318 230.3762833 6800
[Modified by dbrowne1, 11:17 PM 12-26-2001]
Re: EVO CAI vs. K&N Panel - BLOCK 120 DYNO TEST (black2001aww)
Ok, now go slap on the BMC CDA and get back out there and test that too! Serioiusly though, nice work. I'm too much of a wuss to take my car to 6800rpm... but that is some nice peak HP.
What other mods do you have? I'm guessing you have chip and 3" exhaust?
Oh, and 177.9 / 5252 * 6800 = 230. What's listed looks right to me.
Re: EVO CAI vs. K&N Panel - BLOCK 120 DYNO TEST (Gatorfreak)
so going by the increase of the ITG drop in fitler over the dropin K&N, It would just be a hp or two under the evo intake, for what 60 bucks?? And they don;'t fall out, sorry had too.
chris
[email protected]
Discussion Starter · #6 ·
Re: EVO CAI vs. K&N Panel - BLOCK 120 DYNO TEST (chris86vw)
quote:[HR][/HR]so going by the increase of the ITG drop in fitler over the dropin K&N, It would just be a hp or two under the evo intake, for what 60 bucks?? And they don;'t fall out, sorry had too.
chris
[email protected][HR][/HR]​
Mine hasn't fallen out yet. Everything looks real solid too. I tightened those clamps REAL good and pulled and twisted on everything, especially the filter.
And the ITG doesn't make a cool BOV sound and a darth vader sound when you start sucking in air. So there.
How was the ITG vs. K&N test done? Static dyno, 120 dyno, what car?
Gator-
Mods are in my signature. The GIAC chip is in right now, and I have a 3" exhaust from turbo to tailpipe (which means I run out of revs before I run out of HP).
[Modified by dbrowne1, 9:10 PM 12-26-2001]
Re: EVO CAI vs. K&N Panel - BLOCK 120 DYNO TEST (dbrowne1)
quote:[HR][/HR]And the ITG doesn't make a cool BOV sound and a darth vader sound when you start sucking in air. So there.
How was the ITG vs. K&N test done? Static dyno, 120 dyno, what car?[HR][/HR]​
My ITG does, you just have to do it right, Who wants that noise anyway, its just plain annoying like a BOV.
AS for my tests they were donw on my KO4 jetta, K&N average abotu 5hp over stock paper filter, ITG averaged about 12hp over a stock filter, and no fitler at all averged abot 15hp over a stock filiter. THis was done on a mustang dyno, all the same day, all whithin an hour of each other, all intake and IC starting temps were whithin 5 degrees of each otehr for every run.
chris
[email protected]
Mods interpolated on same RPM point. Interpolation would have been better it time column was included.
RPM, EVO CAI, K&N
1750 45.6 34.7
1800 48.9 39.1
1850 52.1 43.5
1900 55.5 47.6
1950 58.7 51.6
2000 61.5 55.5
2050 64.2 59.1
2100 67.2 62.5
2150 70.3 65.7
2200 73.6 68.6
2250 76.6 71.6
2300 79.1 74.6
2350 81.1 77.5
2400 82.8 80.4
2450 84.6 83.1
2500 86.5 85.6
2550 88.7 88.1
2600 91.1 90.5
2650 93.6 92.9
2700 96.3 95.1
2750 99.1 96.9
2800 102.0 98.4
2850 104.9 99.6
2900 107.9 100.8
2950 110.7 102.2
3000 113.2 104.1
3050 115.4 106.5
3100 117.2 109.4
3150 118.9 113.0
3200 120.8 116.9
3250 123.3 121.1
3300 126.4 125.3
3350 129.9 129.2
3400 133.3 132.9
3450 136.2 136.0
3500 138.7 138.8
3550 140.7 141.0
3600 142.5 142.9
3650 144.1 144.6
3700 145.6 146.2
3750 147.2 147.8
3800 148.9 149.3
3850 150.6 151.0
3900 152.5 152.7
3950 154.3 154.4
4000 156.1 156.1
4050 157.8 157.8
4100 159.5 159.4
4150 161.1 161.0
4200 162.8 162.6
4250 164.3 164.2
4300 165.8 165.8
4350 167.1 167.3
4400 168.4 168.7
4450 169.5 170.0
4500 170.7 171.3
4550 171.8 172.5
4600 173.1 173.7
4650 174.5 174.9
4700 176.2 176.1
4750 177.9 177.4
4800 179.8 178.8
4850 181.6 180.1
4900 183.5 181.5
4950 185.2 182.8
5000 186.8 184.2
5050 188.2 185.6
5100 189.6 187.0
5150 190.9 188.3
5200 192.2 189.7
5250 193.4 191.0
5300 194.6 192.4
5350 195.7 193.6
5400 196.9 194.7
5450 198.2 195.7
5500 199.3 196.5
5550 200.3 197.1
5600 201.1 197.5
5650 201.8 197.8
5700 202.7 198.2
5750 203.7 198.7
5800 204.8 199.2
5850 206.1 199.8
5900 207.2 200.4
5950 208.2 201.0
6000 209.0 201.7
6050 209.9 202.5
6100 210.9 203.5
6150 212.4 204.8
6200 214.5 206.2
6250 216.6 207.5
6300 218.4 208.8
6350 219.9 210.2
6400 221.0 211.7
6450 222.1 213.2
6500 223.3 214.8
6550 224.7 216.4
6600 226.0 217.9
6650 227.3
6700 228.5
6750 229.6
6800 230.5
Discussion Starter · #9 ·
I need a K04 too. My car now has an intake and exhaust worthy of a detroit diesel but a tiny little snail pushing the air through.
If I get a GT25, T3, or something like that, do I need a new DP or just manifold?
quote:[HR][/HR]I need a K04 too. My car now has an intake and exhaust worthy of a detroit diesel but a tiny little snail pushing the air through.
If I get a GT25, T3, or something like that, do I need a new DP or just manifold?[HR][/HR]​
yes, you will need a new DP... something we are working on. just as soon as i can get my hands on an atp manifold, we will have dps avail for the T3 setup from atp that will bolt directly to our cat.
oh.. and, yes, you will need a new manifold.
Re: trying to figure out how to do that on Excel (dbrowne1)
Each Y-series in Excel can have its own X-series so different RPM columns are not a problem. I'm going to post a dyno-day spreadsheet where VAG-COM logging was done simultaneously with the Mustang dyno. Graph examples will be included.
Re: trying to figure out how to do that on Excel (chris86vw)
Would it stop logging for several seconds and then start again? That has happened to me some. John S has mentioned that can be caused by Microsoft FindFast. Gotta kill that.
Discussion Starter · #16 ·
Did you rename the log file or overwrite another one (because of the default filename)? I couldn't get mine to log if I renamed the file before logging it, so I used the default and then resaved it as an excel file if I wanted to keep it.
quote:[HR][/HR]No mine just said it was logging but then it never acutally did, I even did a search to see if it was put in some other part of my computer, nope it just wasnt' there.
chris
I had that happen a few times, I clicked log but never clicked start. One time it was a 6th gear speed limiter test, darn.
Nice numbers. Do you find fuel economy problem with EVO CAI or K&N? Some say they experience fuel econ drop with K&N.
1 - 20 of 20 Posts
