1 - 10 of 10 Posts
Like the title says I get excessive vibration when i exceed 55 mph, anyone have any ideas what it could be. Please help.
MODS:
17 inch rims
lowered
stage 4 motor mounts
Those are the only mods i can think of that could cause vibration.
Re: Excessive Sterring Wheel Vibration...PLS HELP! (SOHCU)
your tires need to be balanced.
Discussion Starter · #4 ·
Re: Excessive Sterring Wheel Vibration...PLS HELP! (ninetyseven)
Thats what i thought to but just put a set of Parada Spec 2's mounted balanced and aligned all at the same time. Before these tires were mounted there used to be like a plastic cap or bearing between the hub and wheel, no there is nothing just checked it.
centering ring?
what kind of wheels do you have?
Discussion Starter · #7 ·
I guess thats what its calles no to sure . The rims are 17x7 Mas Italy Rogers.
Discussion Starter · #8 ·
Re: Excessive Sterring Wheel Vibration...PLS HELP! (DHill)
Sears Automotive reapir center. When i brake its perfectly fine no vibration at all. Its really starting to piss me off, never had this problem before.
Discussion Starter · #10 ·
Re: Excessive Sterring Wheel Vibration...PLS HELP! (MikeBlaze)
Thanks guys and girl. I guess i will go get them balnced today. Thanks again for the help.
1 - 10 of 10 Posts
