1 - 8 of 8 Posts
WHAT'S THE BEST MATERIAL TO MAKE AN EXHAUST GASKET OUT OF FOR BETWEEN THE TURBO AND THE DOWN PIPE.. I TRIED COPPER .. DOES'NT SEEM TO WORK
Re: EXHAUST MANIFOLD MATERIAL??? (zornig)
the copper sucks, i tried and it is a PITA to bend, too thin, i would say just get one from the dealer,
Re: EXHAUST MANIFOLD MATERIAL??? (2kjettaguy)
Quote, originally posted by 2kjettaguy »
If both surfaces are machined well no gasket is necessary...
I use none - no problems ever.
This is true, the older A2 VW diesels did not use gaskets between the turbo and the manifold, they did this to avoid possible failure, they did come with Titanium bolts though...
If you plan to use a gasket, you should purchase a pre-made multilayer stainless unit with pressure rings pressed in, this is what we use on all of our T3 and T4 based systems. Any other material or flat sheet is not optimal.
-Rich
Re: EXHAUST MANIFOLD MATERIAL??? (I-Rocco2)
403 Martensite Sheet stock hammer formed. Inconal and Hastalloy are very hard to machine. 316 Crack easy after welding.
1 - 8 of 8 Posts
