1 - 5 of 5 Posts
mine is rattling really bad and i want to remove it. i did some searching on vortex and everyone said it was ok to just remove but what do i do with the hose that goes from the shield to the air box. i don't really get y it is there maybe i will just pull it off
Banned
Re: Exhaust manifold shield (fastmaxxcooper)
The rattling is easy enough to stop without removing it. Just reach over the engine, grabe the shield, and gently pull it up a little bit, putting a slight bend to it. This will stiffen it up, and stop the rattling.
how can that help its a 3d shape already, the shield has ribs in it and curves down idk if a 98 is different from the other years tho
Re: (fastmaxxcooper)
just find where it's cracked, and bend it in that spot. As long as the cracked spot is contacting itself, your car will continue to moo like a cow at that particular RPM it always does.
ok mine is different from everyone else's cuz mine had two nuts and then it slid off and i just took the hose off im gonna see how it runs
1 - 5 of 5 Posts
