I've had a set of Mad Max Control Arms for several years now, with only 20,000 miles. While doing some maintenance on the car I noticed that the rear upper poly bushing has around 1/4" of play in it when rocking the tire. I had a shop install the arms so I never noticed when they were originally installed, but the bushings themselves don't seem to fit very well. In photos of the arms online some of them have metal washers on the sides of the bushings (those weren't included in the arms I received).
Are there any off the shelf bushing replacement options available that would fit the Mad Max rod end? I've heard that the Gruven poly rod ends will thread into the Mad Max arms but I'm not positive about that and I would ideally only replace the bushings that actually fit and not the entire assembly. However, it looks like the metal sleeve itself is too narrow as well? Would a Superpro bushing for the stock arms fit? 20,000 seems like an unusually short lifespan.
