Re: explanation of cams (phat-black-dub)
ok, here's a brief explanation...
the numbers....
260 for example, this is most likely the duration of time that the intake valve stays completely open. from seat to seat. or open to close. this is measured in degrees. so for every complete rotation of the camshaft, the intake valves are opened for 260 degrees out of a 360 degree rotation of the camshaft. make sense?
lift numbers are sometimes given as well...
example, .445 lift means at BDC(piston at bottom dead center) the intake valve is open .445 of an inch. simple as that.
as far as performance goes...
the more duration your cam has, the less bottom end you will have. but you will gain hp accordingly at the other end of the rpm range.
camming a forced induction engine...
mild cams are usually recommended with forced air induction systems(turbo, supercharger)
basically, the principal of forced induction is the keep the air in each cylinder as long as possible to create higher compression, cumbustion chamber pressures, etc.. the idea of a radical cam is to move the air through the cylinder as quickly as possible without the aid of forced air(I.E. long duration, high lift)... so a real radical cam is not going to give you great gains with a forced system. something intermediate would be more beneficial. http://****************.com/smile/emthup.gif
