Re: (waterboy86)
waterboy86 (6:25 PM 12-2-2006): hey whats up?
tolusina (6:27 PM 12-2-2006): ?
waterboy86 (6:32 PM 12-2-2006): oh..check my post for fan switch...i just posted because i didnt get a response right away...i should be MORE patient!!
tolusina (6:39 PM 12-2-2006): does your fan operate now on high speed, not on the other three?
waterboy86 (6:44 PM 12-2-2006): it works when tapped to the battery...made 2 leads pos and neg...works!!...but i believe it's the resistor..or maybe something else...there's not a relay on the fuse box for the fan is there? everything looks okay for the switch...there is a grove for the harness to the switch which i matched up but nothing happens...the new(used) switch i got today has 4 settings as opposed to the normal 3
tolusina (6:50 PM 12-2-2006): Ok, back up a bit, know I know why I haven't posted to your thread before.
1) What year is the car?
2) Does the car have AC? If yes, factory or aftermarket?
3) Full symptoms please.
4) Do you have a bulb type test light?
5) Do you have a DVOM or other multi-meter?
waterboy86 (6:55 PM 12-2-2006): sorry bro....lets fast forward....87 cabby..no a/c..the fan blower for fresh air is working when tapped...no action from switch on inside panel. and yes!! you replied to "fan blower not working" today at 6:20 p.m.
Now help me...LOL
waterboy86 (6:56 PM 12-2-2006): i do have multi meter no bulb test light
waterboy86 (7:00 PM 12-2-2006): okay i see you posted to gasparj back ion 5-16-06 about the paper clip thing...i am searching...
waterboy86
___________________
IM content pasted/posted for archival/informational purposes.
___________________
First, correct schematic for the car........
Do the wipers, rear defogger and headlights all work?
If those are good (rear defogger optional), with your multi-meter, check for voltage on both sides of the fuse, S14. Check for power at the black/red terminal of the fan switch, look for burning or corrosion on the wire connector.
Paper clip jumper (paper clip may heat up, especially when testing high speed) black/red to white for low speed, black/red to yellow/black for medium speed, black/red to yellow for high speed.
If red/black is dead, use any available fused power source.
(Non AC cars have only three fan speeds, AC cars have four)
Ground connection is at one of the multiple grounds beside the relay plate.
