Re: FAQ - Carbs (the12for12)
Well I have been speaking with MSD about this option of reversing the magnetic leads on the MSD 6 box for a "Nice Advance curve" and here's what they told me on the phone
Yes you can reverse the leads and it will advance the timing but the problem with this is
In the normal (per instructions) position of the wires the spark happens at the beginning of the timing cycle and it works great on 99.9% of all cars
but by reversing the leads, yes, you give the car a timing advance but now the spark happens at the end of the timing cycle and you will have one hell of a time getting the timing tuned properly if at all
So basically Yes it dose advance the timing but it really doesn't do it properly and more than likely it won't function correctly
Quote, originally posted by the12for12 » |
A.IGNITION 2.Aftermarket ignition control: Simply buy an MSD 6A(L) or Crane HI-6 ignition box and use the magnetic pick ups from the stock distributor and you will have a working ignition. The typical belief of the ignition boxes is that they do not have a built in ignition advance. However, the MSD has a nice built in feature that is not found while reading the instruction manual. By reversing the magnetic leads, the MSD can give you a nice timing advance curve. You simply set the ignition at you want at idle (stock is around 10-15 degrees BTDC). As you blimp the throttle, you will find that the timing jumps to around 20-35 degrees BTDC. |
