1.8 GU 8v twin DCOE 40s
Weber DCOE experts please; I'm trying to jet my carbs so suggestions. I hope this helps others as it is very difficult to find anything on 8 valves with effect on drivability/performance. Here's my progress/trial and error write-up:-
Car is 1989 1.8GL UK right hand drive (brake servo in the way of cylinder 1 intake).
Facet 60104 fuel pump (inherited, not by choice).
Malpassi 3-way fuel regulator with return, guage set to 1.5psi, reasonably steady control.
Mangoletsi manifold, ported/port matched.
Massively ported GU head with old inlet manifold coolant feed blocked off. Exhaust/inlet on same side (rear of engine).
Standard valves, springs, hydraulic lifters, seats standard (throats have been widened/blended).
Camshaft is Newman 272 duration, 10.8mm? lift
Timing/ignition is standard GU distributor, vac advance connected to cyl 4 on Mangoletsi manifold with big green ball (from Pierburg 2E2) as vac pulse compensator.
Timing set to standard flywheel mark with vac disconnected from distributor at idle (is 18 degrees BTDC?).
Twin DCOE 40s only identification on them is '3K', possibly Toyota? They have 3 progression holes and originally had 30mm chokes.
Jetting:-
My starting point, more or less book guide values.
Chokes: 34mm
Mains: 135
Air Correctors: 185 (i.e, + 50 over mains)
Idles: 50 F9
Pump Jets (in carb already) : 35 (small?).
Emulsions: F16
What did it drive like? Very jerky on acceleration, almost like random missfire very scarey. Setting the idle screws, they were only 0.75 turns out (rich?).
Problems arise on transition about 2500rpm. Then no power and quiet running after 3000rpm, at wide open throttle to 4000rpm, too scared to go beyond 4000rpm. Otherwise was a pleasant drive around town.
I assumed the idle jets were too rich and the mains were way too lean. I already had some 180 air correctors from the old carb setup. I plonked these in to see if it helped richen the main circuit. The difference was barely noticable, but did make some small improvement (less jerking/missfire/smoother).
Next step I tried was 145 mains, I bought 125s as backup in case I was wrong too
. This made a drastic change to the whole setup especially at 3000-5000rpm where there was noticably more power, yay! However, drivability low down took a nose dive (stalling) and there was still alot of bucking/jerking.
Next I had already some 45 F8s from the old carb setup so swapped these in. Significant smoother town driving, however is still jerky at slow throttle transitioning to wide open throttle. No noticable difference from 3000-5000rpm. Wide open throttle sounds lean to me as in there isn't a roar of power, more like the sound of drawing air. Idle screws now set about 1 full turn out on each barrel. The 45 F8 has a massive air hole versus the 50 F9 so is leaner.
Current Jetting:-
Chokes: 34mm
Mains: 145
Air Correctors: 180
Idles: 45 F8
Emulsions: F16
Guys, what is my next move? Here is my personal jet 'arsenal' to play with:-
Chokes: 30, 34
Emulsions: F16
Idles: 50 F9, 45 F8
Mains: 115, 125, 135, 145
Airs: 180, 185, 200
Pump Jets: 35
My gut feeling is that the mains can go richer still. +10 on the mains improved alot of the mid-range/top end. I ordered in some 160 air correctors, but some div sent me 1x160 and 3 x 100s, I could get a set of drill-bits I suppose and solder? Save me buying more jets.
Is it worth up-sizing the pump jets? These are more expensive parts.
