Re: FAQ (yellowslc)
Thanks to Marcel we have some setups:
Front 5x100, stock width, 02M gearbox
Front suspension: Golf Mk2, VR6 hubs in G60 spindles
Driveshafts: Left Seat Ibiza TDI, part# 6Q0 407 271 J. Right shortened 4Motion, hollow type.
Front brakes: VR6 288, Audi TT or bigger bolt-on kits, adapter needed. (ESC Tuning.)
Prop shaft: Passat G60 middle section with 100mm CV, shorted TT item front and shorted G60 item rear.
Rear 5x100, stock width
Rear left driveshaft: G60 Syncro shaft, shortened, inner CV joints 4Motion, outer VR6
Rear right driveshaft: G60 Syncro shaft, shortened, inner CV joints 4Motion, outer VR6
Rear trailing arms: G60 Syncro
Rear hubs: VR6 Syncro, optional VR6 front hubs and 4Motion outer CV-joints
Rear brakes: VR6 Syncro
Front 5x100, wide track, 02M gearbox
Front suspension: Golf Mk3 Gti 8v 16v VR6 / Corrado VR6, 5x100
Driveshafts: Custom driveshafts with 4Motion inner CV and Sharan outer CV.
http://www.driveshaft.co.uk/index_content.cfm
Front brakes: Audi TT or bigger bolt-on kits
Prop shaft: Passat G60 middle section with 100mm CV and, shorted TT item front and shorted G60 item rear.
Rear 5x100, wide track, 4Motion outer CV joints
Rear left driveshaft: G60 Syncro shaft with CV joints from 4Motion
Rear right driveshaft: G60 Syncro shaft with CV joints from 4Motion
Rear hubs: 5x100 VR6 front hubs
Rear brakes: stock VR6 Syncro
Rear trailing arms: VR6 Syncro
Front 5x100, wide track, 02C / 02J gearbox
02J 4Motion (from 2000) or 02C gearbox, optional upgraded internals.
Skoda Angle Drive, part# 02C 409 053M.
Driveshafts: Stock VR6 Syncro with Sharan outer CV
Prop shaft: Stock G60 Syncro with optional 100mm CV's from Audi TT
Front 4x100, stock width, 02C / 02J gearbox
Front suspension: Golf Mk3, 4x100
Driveshafts: Stock G60 Syncro
Front brakes: G60 280 mm, optional S2 callipers. 305 mm. Brembo from Seat Ibiza Cupra R
Prop shaft: Stock G60 Syncro, optional 100 mm CV's from Audi TT
Rear 4x100, stock width
Rear left driveshaft: G60 Syncro shaft, shortened, with inner CV joints from 4Motion
Rear right driveshaft: G60 Syncro shaft, shortened, with inner CV joints from 4Motion
Rear hubs: G60 Syncro
Rear brakes: G60 Syncro
Front 4x100, wide track, 02C / 02J gearbox
Driveshafts: Stock Mk3 Syncro
Front brakes: G60 280 mm. Optional S2 callipers, 305 mm. Brembo from Seat Ibiza Cupra R
Rear 4x100, wide track
Rear left driveshaft: G60 Syncro shaft, with inner CV joints from 4Motion
Rear right driveshaft: G60 Syncro shaft, with inner CV joints from 4Motion
Rear trailing arms: Golf 3 Syncro
