1 - 6 of 6 Posts
I am running APR DPP and seem to always get the following fault code when I switch between ECU programs:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
It shows up in several controllers (engine 001; CAN gateway 019; KOMBI 017), does not come back until you switch programs again, and does not seem to cause any problems.
Anyone else have this issue or is my ECU just special
. Any ideas why this happens?
Discussion Starter · #2 ·
Re: Fault codes generated when switching between APR ECU programs? (JTwGTI)
I have the APR DPP as well, however, I have not had any of those problems. If I were you, I would go back to where I had it installed and make them fix it until it's right. I hope everything turns out okay though...
my apr software hasnt triggered any codes. have you asked apr about it?
Re: Fault codes generated when switching between APR ECU programs? (rockit)
Quote, originally posted by rockit »
1 - 6 of 6 Posts
