I have reviewed most of the aftermarket clutch threads and am looking for a solution to clutch creep. I had a Spec 3+ with the SM steel fly wheel installed with my turbo build along with the NLS shim kit. We are about 700 miles in and I am experiencing clutch creep in reverse and 1st. Could it be a faulty throw out bearing (a new OEM was installed with the clutch)? Once in a while the car will get locked in reverse, it will release is the clutch is fully disengaged or your turn off the car.
Any ideas for a solution. I'll have the throw bearing replaced if need be, but I wanted to see how other have address this issue.
TIA
TIA
