1 - 5 of 5 Posts
Discussion Starter #1
I have to change my haldex oil. Has anybody filled their haldex through the oil level check hole. It seams easier if you use a hose. I all ready see a problem fill the oil from the drain hole which is recomended in the manual. if I use the cheap calk gun, i'm going to have clearence problem even if I have my car as high as I can go because of the rod of the calk gun.
Any suggestions?
Re: Filling your Haldex (4shizzy)
I used the check hole and the hose/tube setup (thanks pal & climbingcue) without any issues. keep the length of the tube to a minimum, As you'll end-up "losing" whatever remains in the tube at the end.
It was real easy and I avoided the mess that can be expected by filling through the drain hole.
See Ian's warning regarding the check hole nut in this thread: http://forums.thecarlounge.net...12397
Discussion Starter #3
Re: Filling your Haldex (KrzeVR6)
how would you know if you knock the blind nut off? It seams ridiculous to have something that loose inside like that.
You'll know when the bolt won't thread
I didn't find it too hard on the three changes I did to put it in the drain hole, you just have to have the bolt ready and be quick- kind of like a game.
Discussion Starter #5
nevermind I found the thread. thanks. http://****************.com/smile/emthup.gif
1 - 5 of 5 Posts
