Re: Finally-PSS arrived (SLC4EVER)
wait a couple of weeks, they're on back order for the wrenches. you don't need any bushings,bearings,etc. unless your stock stuff is clapped out. my car was fine, and i'm at 83k. look in the instruction manual and check for the measurement they give you for lowest height. it's hard to find since most of it's in German, but it the part that says measurement #'s of 220-2something. that measurement is done from the top bolt of the 2 bolts on the bottom of the front shock up to the bottom of your main spring. do this on all four and it will save you time on setting up your cars height. if you go lower than they recommend, the spring isn't under enough preload and the car likes to bounce.
