Re: finally replaced door lock module... DIY as follows (marainwater)
I just bought a TDI yesterday and have already noticed that the driver door does not lock. The remote will lock all doors except the driver door; same for the inside switch. I can push down the driver lock manually once the door is closed (but not before). The door will lock manually when I use the key if all the other doors are locked already (for instance, I get out and hit the lock button on the remote, I have to put the key in and manually lock it). However if all the doors are already unlocked, they can all (including the driver) be locked with the key (it is the electrical lock not the manual). I thought it might be the lock sensing switch, but I was confused when it locked electronically when all the doors were unlocked with the key. I am just trying to identify the problem, and see if I can get the dealership to fix the problem for me.
