In case our new Mk2 project car didn't already make it obvious, we've got a soft spot for the 2nd gen Golf. Seemed a good day to share another one we've found up for sale in our forums and also on Craigslist . This great-looking '91 GTI 16V is currently owned by Project R32  and is up for sale at what seems like a very reasonable $7800.
What's so special about the car? Well, in addition to being one very clean specimen of the late Mk2 GTI era, it also sports a very clean look and tasteful list of upgrades including 6-speed conversion... Well, let's just let the owner's list of mods speak for itself.
Find of the Day: 1991 GTI 16V
Current mods as it stands:
Motor
2.0 16v- Fully rebuilt at 149k, currently 155k on it. painted and cleared block with the following done at 149k by my Uncle who is the PO.
Stock bottom end w/ new pistons rings seals and bearings
crankshaft shaved and balanced
rods balanced
VW motorsports windage tray in oil pan
2.0 cylinder head with 3 angle valve job
Schrick Cams 268/276
Autotech HID valve springs
Techtonics adjustable cam gear
Mild port and polish
painted valve cover
50mm intake manifold painted
new water pump, starter, timing belt, drive belts and water pipe
EIP solid front motor mount
SS braided fuel lines w/ custom injector adapters
Borla exhaust
cat delete
center muffler delete
dubspeed big bore intake
Transmission was rebuilt also at 149k bead blasted painted and cleared with the following specs:
Quaife LSD w/ 3.94 ring and pinion w/ ARP bolt kit
VF engineering 6spd add on conversion on the 020
6 puck clutch w/ EIP lightweight flywheel
HPA poly trans mount
Neauspeed short shift
Suspension was done around the same time.
Bilstein PSS9's
VR6 front upper strut mounts
Neauspeed 22mm Front Sway Bar
OMP lower control arm to rad support tie bar
autotech upper front adjustable strut bar
Dubspeed rear strut bar
Poly bushings everywhere and the car is corner balanced.
Brakes were done at 145k w/
Front 11" G60 conversion
Rear MK4 calipers
Cross drilled F&R rotors and mintex red box pads
Neauspeed braided SS lines w/ ATE superblue fluid
22mm master cylinder
Wheels
16x7.5, 16x9 Borbet Type A's
16x8 TSW EVO's
The exterior has some cool little mods too:
Smoked tails w/ euro bulb tray and working rear fog
Quad round H4 crosshairs w/ yellow city lights
MK3 door handles
Kamei upper grill support
smoked bumper, banana lights and smoked euro fender markers
25% tint
OEM sunroof deflector
Stubby Aetenna
Interior
Momo race wheel
aluminum door pins, shift knob, and e-brake
autotech dead pedal
aluminum pedals
Jamex 3pt harness
red-stiched shift and e brake boot
custom silver guage face overlays and heater contros
blue/red MK4 style dash light conversion
Sony headunit with MB Quart tweeters, polk door speakers and infinity 5x7s
black felt headliner
SS door sills w/ GTI 16v logo
Factory 16v mats
VDO oil pressure, water temp, and oil temp guages w/ silver bezels
Factory Fischer center CD cubby
To anyone interested in this GTI, the car looks to be in New Hampshire. Again, you can find the listings in our  forums  and also on  Craigslist
