1 - 3 of 3 Posts
Banned
I hooked it up properlu still does not work, Apperently there is a gound problem since I dont see an intermitent gorund signal when the switch key is turned on from pin 85 iirc,
So I read the Bentely and it mentioned that I should make sure all of the engine grounds are in tact, specially the one underneath the manifold
but I cant find any there
I wanna set this thing on fire
Banned
Re: F'ing Ground Problems :MAD: (QuickA2)
under the intake manifold??
its a little bracket held in by a 6mm allen to the manifold, and a 6mm allen to the head (you can't remove the valve cover w/o removing this piece as it blocks it partially)... it should have 3 wires coming to it, all with metal O connectors, each held in by a nut to the stud... check that as i think its an important one!
I know you're pissed off and everything, but could you give us a little more detail as to what exactly is ****ing up? And are you sure it's a ground problem?
Thanks!
1 - 3 of 3 Posts
