Firing HELP!?
397 Views 5 Replies 3 Participants Last post by  Numbersix
Sup guys, havent been on for a while the car was actually running good,..ok then 89 golf is not firing in one of the cylinders I change plugs and wiresno prob there.. Might one of my injectors be smoked??? what else could it be ???? also how do you test injectors??? thanks alot
1 - 6 of 6 Posts
Re: Firing HELP!? (89GolF89)
please..help
See less See more
You need to test the compression, then fuel pressure, then replace the injector.
Re: Firing HELP!? (Vdubs)
bump?
Did you do what Vdubs said?
1 - 6 of 6 Posts
