1 - 4 of 4 Posts
hi I want to get a new floor jack this car is much lower than what i used to work on.
I would like to avoid lifting it from the control arm, or rocker panel. so i rather lift the car from mid sub frame while the car is at curb height.
any ideas is I would need a extra long reach low profile I would assume the low profile one would be too short i have narrowed it down to two models please let me know what you guys think. thanks in advance
xl reach 399 cad
Assembled Height (cm):
22.00 cm
Maximum Lift Height (in):
24.02 in
Assembled Height (ft):
0.72 ft
Maximum Weight Capacity (g):
2721000.00 g
Assembled Height (in):
8.66 in
Maximum Weight Capacity (kg):
2721.00 kg
Assembled Length (cm):
86.50 cm
Maximum Weight Capacity (lb):
5998.77 lb
Assembled Length (ft):
2.84 ft
Minimum Lift Height (cm):
8.30 cm
Assembled Length (in):
34.06 in
Minimum Lift Height (in):
3.27 in
Assembled Weight (kg):
46.50 kg
low profile 299 cad
Accessories:
Casters, Handle
Maximum Lift Height (cm):
50.00 cm
22.00 cm
19.69 in
0.72 ft
2721000.00 g
8.66 in
2721.00 kg
73.50 cm
5998.77 lb
2.41 ft
  • Minimum Lift Height (cm):
    8.50 cm
  • Assembled Length (in):
    28.94 in
  • Minimum Lift Height (in):
    3.35 in
i bought the low profile extra reach jack it was on sale finally after 3 months of checking every week smh, it won't reach my subframe as the car sits at curb height.
I have to roll on some 2x6's then i can access it easy.
Snap On would of also been a good choice. A great tool for life
It would help if you tried this Pittsburgh 3 ton floor jack. It can lift both low profile and high profile vehicles. Mechanics and DIYers prefer well-made floor jacks that can support heavy vehicles. Pittsburgh 3 ton floor jack https://bestfloorjack.org/pittsburgh-3-ton-floor-jack-review/ out of steel. Expect this unit to hold up to a lot of pressure. The Pittsburgh 3 ton floor jack is super easy to use.
1 - 4 of 4 Posts
