1 - 20 of 26 Posts
Few days back I upgrade my VW JETTA MK6 from standard heated side mirrors to Power Folding Mirrors with Puddle Lights. Credit will be to eastcostvagparts.webs.com & technician Mr. Mazen...
Step 1 - removing door panel as showing here: http://www.youtube.com/watch?v=tzyv8owgI_4 be careful for window switch to break it.
Step 2 - unplug mirror connector from the door module (open connector lock it is red tongue pull it out then pull the connector), and other connectors, be careful for alarm light wire is short.
Step 3 - take out the mirror (one after one) replace it by the new OEM mine part # 5C7857507C, it is one screw from inside then from outside pull from down to up and take it out.
Step 4 - to fix the new mirror you insert it in its place from upper side under window rubber then push it to fit in its place, now from inside tide the screw normally.
step 5 - connect all wiring in the correct place, fix door panel, clean then go to VAG-COM.
Step 6 - VAG-COM module 42 - door elect. Driver side folding mirrors installed + puddle light
Step 7 - VAG-COM module 52 - door elect. Passenger side folding mirrors installed + puddle light
pictures are here for VAG+COM
http://www.4shared.com/download/o401km-l/VCDS.bmp?tsid=20130625-152938-b8fcda59
http://www.4shared.com/download/nBh5zfVF/vcds4.bmp?tsid=20130625-153015-1e997fd3
http://www.4shared.com/download/Q27UqECT/vcds2.bmp?tsid=20130625-153034-620e7f4a
http://www.4shared.com/download/Dd4xBTgG/VCDS3.bmp?tsid=20130625-153052-2c8121a7
folding mirrors are not working yet, we (my self, eastcoastvagparts.webs.com and Mazen...) still working to figure out why still not foncutioning, research by eastcoastvagparts.com still going on, we ask a hint from VCDS Supports we are waiting for their feedback... any other update positive or negative we will keep post it.
Also guys wait to see other modification Retrofitting OEM LED Headlights & LED Tail Lights; Rain & light sensor, Auto dimming mirrors with clear wiring harnesses less works, all parts supplied by eastcoastvagparts.webs.com
Again thanks to eastcoastvagparts.webs.com & Mazen...
So cool I have been wanting the power folding mirrors on my car and hoped they had one with the puddle lamps. Keep me updated on this so I can buy a set for myself.
Discussion Starter · #4 ·
for more info check with eastcoastvagparts.webs.com
If husseinayash resolves his Folding Mirrors issue, his solution will only apply to GLI vehicles. His Saudi Jetta is an ROW vehicle based on the BCM PQ35 electrical system. NAR Jettas are based on the BCM PQ25 electrical system. Likewise, whatever he did to get Puddle Lights will not work on NAR Jettas.
Discussion Starter · #7 ·
you are absolutely right CDN TDI, mine is BCM PQ35 H; which is mean CECM Highline, as I guess there was CECM Midline & lowline...
Puddle lights sold on USP...will those work for non GLI? The ones under door (where reflector is now)
Question?
I have 2013 GLI and I installed front door exit light but the rear is giving hard time. Its coded right but the light just dont lite up any idea why? Can I just tap into one of the wires? Thanks.
Discussion Starter · #12 ·
After all researchers need doors module to be change driver side & passenger as I guess and I'm still checking what are the possible way to change only modules not the Window motor with module...
Any idea if folding GLI-style mirrors are available anywhere?
I am also wondering if mirror puddle lights and puddle lights installed in the interior door reflector positions could be made to work at the same time without throwing error codes?
Discussion Starter · #14 ·
Mirror puddle lights and puddle lights installed in the interior door reflector can be for GLI as far as i know, you have to PM verebs1 he will guide you... For mirrors folding mirrors, door module and switch need to be change to get it work... Again as far as i know!!!
Sent from my iPad using Tapatalk
I haven't been able to find any folding mirrors in the specific GLI shape, do for now I probably will just install the puddle lights.
I know this isnolder but lmk if you tackle this. I want to do it as well but idk where to tap into as i have the 2014 se
Sent from my interuterine device.
This helped! Thanks!
This helped me out! Thanks a lot!
I'm only doing the under door puddle lights.
Any idea if I can do the coding before I do the install? My friend that has VCDS lives a good hike away and I'm heading there this weekend. I code for him and use his software for mine!
They should not.
I got manual folding GLI mirrors and then added the puddle lights myself with OEM/aftermarket parts. I got the power from the interior front dome light, then ran the power out into the doors with OEM repair wires that were installed in the front door wiring harness connectors.
1 - 20 of 26 Posts
