21 - 26 of 26 Posts
2014 Jetta GLI
I've found the multiple versions of power folding GLI side mirrors on aliexpress, along with the power folding mirror adjustment knob. The power folding mirrors are available with a 12-wire harness and a 6-wire harness. The north american GLI doesnt have memory seats as an option, so I'm not sure how either the 6-wire or 12-wire power folding mirrors will need to be wired into the existing harness.
You would be able to do it with Euro style mirrors, they are Power Folding.
Two ways to go is use the mirrors 5C7 857 508AR and 5C7 857 507AM and use a universal folding switch, this way you
do not have to replace the Window Door Regulators and no Coding.
Or do the original factory install, you will need the mirrors and the door modules and switch and do the coding.
3C0 959 792J and 3C0 959 793J door modules, 5C7 959 565N mirror switch.
You will need to copy the coding from the old module and make adjustments from there
2014 Jetta GLI
My 2014 GLI has P/N 3C7 959 792B and 3C7 959 793B door modules as the factory equipment. Are the 792B and 793B part numbers electronically equivalent to 792J and 793J part numbers?
Im not a 100%, of the bat I would think not since the software inside might be different, as stated in the beginning of the post they installed the mirror but they wont fold and now they need the new door control modules. the J version seems to be for Mexico and European market, and I assume because those markets do have the Power Folding mirror options.
I bought a complete set, with door switch and both door control modules complete for $385 and that includes both mirrors, VW OEM original.
2014 Jetta GLI
Correction on my previous statement about the door module p/n that I have in my GLI. They are 3C0, not 3C7. I double checked that the 507 and 508 part numbers are legit for the euro spec GLI, located them on aliexpress, and ordered them, for better or worse. These are the power folding GLI mirrors that have 8 wires going to the connector.
Or maybe I'm just confused from working on too many projects LOL. When the mirrors come in I'll have something interesting to goof around with.
2014 Jetta GLI
How many pins were populated for the power folding mirrors, p/n 5C7 857 508AR and 5C7 857 507AM? The mirror switch, p/n 5C7 959 565N, how many pins does that harness have?
21 - 26 of 26 Posts
