1996 runs great built at Audi plant in Emsden,Germany
Wolfsburg Edition
Full rebuild
Passat TDi
New motor
New clutch/flywheel sachs quiet clutcg
New clutch release lever kit
Clutch/release and throwout bearing
New glow plugs
New starter
New AGM.battery
New turbo
New cam seals
New fuel filter
New water pump and timing belt
New serpentine belt
Completely re-sealed injection pump
Newer struts
Newer brakes
Intake manifold replaced with a clean one
Tires are good
Brakes are new
Suspension was replaced in 2016/2017 with BILSTEIN Struts
Oil changed 5w40synth
New CCV breather tube
New valve cover grommet
New injector seals
New turbo oil feed line banjo washers
New mahle thermostat
New coolant flange
New coolant g13
New oil filter flange gasket
New rear main seal
New oil cooler gasket
New intermediate shaft seals
New single mass fly wheel bolts
I have all the receipts all of this was just done 8/2021 by VW mechanic
Last few drives im getting
56 -58 miles per gallon
$3900 or best offer
PLEASE TEXT FOR MORE INFO/ PICS 856 220 7265
Wolfsburg Edition
Full rebuild
Passat TDi
New motor
New glow plugs
New starter
New AGM.battery
New turbo
New cam seals
New fuel filter
New serpentine belt
Newer struts
Newer brakes
Tires are good
Brakes are new
New injector seals
New coolant flange
New coolant g13
New rear main seal
$3900 or best offer
