Ok I’ll look into ms2 or 3
Sent from my iPhone using Tapatalk Pro
Do these come with mounts, mounting hardware, linkage, etc? Or just carbs and manifolds?16v Weber DCOE 45s w/ twin manifolds. Everything is Brand new, only been mocked up once or twice.
Friends project is going another direction.
$1000
carbs, manifolds and mounts. everything you see in the photos. no linkage.Do these come with mounts, mounting hardware, linkage, etc? Or just carbs and manifolds?
Done with carbs?I have everything you need to convert your 16V to carbs. @ DCOE 45 webers, carter pump, pressure regulator, manifold, MSD ignition box, MSD timing adjuster, MSD coil, Taylor wires.
Never actually used them. Bought them with an engine and thought they were cool and I was about to put them on my car when I read about carbs and figured out MPG's... this was going on a daily driver so it is a NO NO for me. I guess they are more suited for tracks / shows cars. Or people living near gas city.Done with carbs?
What are you running then?Never actually used them. Bought them with an engine and thought they were cool and I was about to put them on my car when I read about carbs and figured out MPG's... this was going on a daily driver so it is a NO NO for me. I guess they are more suited for tracks / shows cars. Or people living near gas city.
I posted a trade offer on FB (burn all the mk1's), I'd rather find a stock scirocco 16V engine management.What are you running then?
Mike, I measured this morning before I went to work. On center measurements are 90mm from hole 1 - 2, ~100mm from 2 - 3, and 90mm from 3 - 4.^ Hey Doug, when you have a chance could you let me know the spacing of the holes in the backing plate? Center to center would be good.
It's unlikely, but I wonder how close the spacing is to the bike carbs...
I appreciate it, I'm about 72 - 95 - 72 which is unfortunately pretty far off...Mike, I measured this morning before I went to work. On center measurements are 90mm from hole 1 - 2, ~100mm from 2 - 3, and 90mm from 3 - 4.
