1 - 20 of 438 Posts
Forum Elder
Discussion Starter #1
For Sale - Wanted To Buy -
Please Post ONLY all wheel drive parts and car related items here. All others will be deleted.
i need the last prop shaft to the rear.
its the axle that is attached to the viscous coupler
i need a price of this and a quote to ship this to v3a8k8 langley bc
F/S: 02C clutch housing - 4 cyl Bell housing $150
I have a clutch housing up for grabs.
I swapped it off of a working syncro gearbox that was slated for a VR6 installation.
So, Here it is - one 4 cyl 02C clutch housing.
150 picked up or - plus shipping takes it.
Ill Clean it up and take new pictures afterward. :beer:
FS 4 Motion Controller complete with modded Haldex box, control unit, display, and cables. I bought this from Carbide but over three years ago. I never intalled it because the car isnt finished yet, but Ive decided to go a different direction. $1000 plus shipping. email at [email protected]
FS: NOS Syncro rear differential
for 85-88 Quantum, I believe. Numbers are as follows:
017 525 d53 e on actual housing, and 017 525 131b on cover
Make offer.
No reasonable offer will be turned down... it's a large piece of uselessness that has to be in my car (live in the barracks, can't store it in my room :rolleyes:)
I bought a drivetrain swap for a 4cyl Mk2 and the guy had both setups. He gave me the R tranny instead of the TT tranny. I lost contact with the guy so I couldnt swap with him. Ive replaced the tranny with a TT tranny so I have this one up for grabs. He mentioned the R system had 50K miles (maybe I got those bits for the rest? The TT was 77k). Everythings tight and clean. No angle drive or starter. $1100 obo plus shipping. Located in Az. Its easier to get ahold of my via email [email protected]
Forum Elder
Discussion Starter #17
R32 6sp Transmission
Approximately 3600 miles.
Removed from a rear-ended R32.
Does NOT include the angle drive
$1600 shipped CONUS
or
$1500 picked up in Charlotte NC
FS: complete B3 Passat Syncro system
92 sedan 249,000 kms, DE headlights, H&R lowering springs, leather, sun roof, good engine and supercharger. Will sell whole car $1000 or complete syncro system for a few hundred more to cover the cost of removing. OBO
Located in Ottawa On Canada
G60 syncro trans w/transfer case & rear end - $350 picked up
Audi tt/r32 center drive shaft - $100 picked up
front axles from either a audi tt or r32 not sure - $100 picked up for the pair
Im in area code 21703. PM on here for best results.
Everything is OBO + shipping (i will ship anywhere) and from a 92 B3 Passat Syncro
Full syncro drivetrain: $1200 + shipping
Full exhaust system that fits 91-92 Passat Syncro and Rallye Golf:
Factory G60 syncro exhaust manifold $75
Factory G60 syncro downpipe: $100
Factory G60 syncro cat pipes: $150
Factory midpipe/dual suitcase mufflers. Front end of the pipe has the stock slip joint that starts after the 2 cat pipes Y together so it will slip right onto your stock dual cat pipe. $75
1 Set Passat Syncro Rear Beam Mounting Plates (4 hole) Redrill 1 hole and they work on mk2/mk3/corrado $75
1 Syncro Viscous Coupling: $150
2 Rear Diff Crossmembers (not the rubber mount/bracket) $100 each
2 Passat Syncro Gas Tanks $75 each
3 Passat Syncro Rear Springs $50 each
2 Non leaking Rear Passat Syncro Struts $50 each
ABS/EDL brake master unit: $75
ABS/EDL ECU: $50
1 - 20 of 438 Posts
