1 - 3 of 3 Posts
Are there any advantages/disadvantages to having both sets in place?
Which set is the primary? The one closest to the head, or the one closest to the air filter?
Thanks.
Re: For those running motorcylce ITBs, did you remove the 2nd set of throttle plates? (xr4tic)
closest to the air filter are the chokes. you don't need them. they're only used for warm-up when used in conjunction with carbs, or at low rpm to simulate smaller diameter runners.
Re: For those running motorcylce ITBs, did you remove the 2nd set of throttle plates? (diablerouge)
i removed them! i have no warmup or cold start iissues
1 - 3 of 3 Posts
