1 - 12 of 12 Posts
Discussion Starter #1
i ordered white 42dd license plate LEDs awhile back and had them on for almost a month.
and one night my friend was driving behind me and called me saying that the left LED is just doing a strobe effect. constantly.
i tried hitting it. lol. didnt go away, took the bulb out, and in again. stil does it.
know the prob? thanks http://****************.com/smile/emthup.gif
Re: for those with LED license plate lights.. (euRo_tuner)
those bulbs are pretty much ****. sorry 42dd, waste of money IMHO.
Re: for those with LED license plate lights.. (JoeBMX)
that's what you get for upgrading your license plate lights.
Re: for those with LED license plate lights.. (KC Jazz)
If it starts to flash, this means the bulb is on it's way out.
I've learned over the years, that the license plate lights must have a voltage spike or uneven power running to them. I use a superbrightleds bulb in mine. It has 9 leds in each bulb, but after about 6 months, a few of the leds will burn out. Then I just replace them, $4 bucks a bulb, no problem.
bright white huh?...
Modified by SPKNGRMN at 9:25 AM 8-27-2006
Re: for those with LED license plate lights.. (SPKNGRMN)
as stated by 42dd with the LED swap on the license plate:
"the license plate lights int he mk4 gti and NB are completely sealed. license plate lights are constantly lit even with the headlights off. this is by far the harshest environment for the fuse style LEDs. these lights MUST be vented in order for the LEDs to last. to vent these lights, remove and unplug the lights. the entire top of the housing must be vented in order for the LEDs to shed their heat. to do this simply cut or drill out the top of the plastic enclosure. if this is not doen the LEDs will only last 1-6 months depending on the relative temperature of your area. Jetta license plate lights are completely vented and do not suffer from this heat issue."
take care of that and I'm sure you wont have any problems afterwards.
Re: for those with LED license plate lights.. (methodicalmayhem)
my leds from 42 design went out too for the second time. but they will replace them every time.
Modified by 16vROCCO20vGLI at 8:11 PM 8-27-2006
Re: for those with LED license plate lights.. (16vROCCO20vGLI)
Quote, originally posted by 16vROCCO20vGLI »
Same thing I've done before.
my dome light suddenly decided not to work anymore. i have had it since April. its a 42dd 42mm white.
will they replace for free
Discussion Starter #10
Re: (Mowgli87)
Quote, originally posted by Mowgli87 »
yepp.. only 1 of the 4 small leds in that dome light bulb was working. told 42dd about it. replaced it for free. i <3 them
Quote, originally posted by SPKNGRMN »
http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif superbrightleds.com
Banned
Re: for those with LED license plate lights.. (Blown05GLI)
leds license plates are , just like the new lexus 300s rear lighthings at night http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif
Modified by BoraBmw at 12:56 AM 9-3-2006
1 - 12 of 12 Posts
