1 - 11 of 11 Posts
Friends, I found a nice mid-milage 97 gti vr6. anything in particular I should look out for? To they tend to have any nagging issues?
Any advice is helpful.
thanks in advance........
dave.......
Re: found a 97vr6 gti i like. anything to look out for? (Dave Corbitt)
Is it stick? and also just make sure you check it over and make sure everything sounds right, I would check for leaks and look for accident damage. Other then that good luck.
Re: found a 97vr6 gti i like. anything to look out for? (pyrogti)
a couple of things:
Check the fog lights for cracks.
The coil pack and plug wires will probably need replacing esp if they havent been so budget $300 for that. They go on all VR6s; nothing wrong with that, just be aware
Re: found a 97vr6 gti i like. anything to look out for? (Ryun)
as long as it's stick http://****************.com/smile/emthup.gif
and dont look like it was seriously fkd up in a crash before... you should be ok...
Re: found a 97vr6 gti i like. anything to look out for? (feeling_sinister)
Check for super sloppy shifter.
Other than that, check for the usuals:
Smooth power window operation
Smooth sunroof operation (tilt & slide)
Drive it hard and make sure the car accelerates smoothly to near redline and the tranny shifts without grinding.
Verify brakes are good, check pads/rotors for excessive wear, and e-brake engages without having to pull up too high.
Have someone rev on the engine and you check out what comes out of the exhaust. Make sure it isn't too much smoke.
Pop open the hood and look for obvious leaks.
Look at coolant overflow tank and see if the fluid still looks somewhat pink.
That's all I can think of right now.
Re: found a 97vr6 gti i like. anything to look out for? (nycvr6)
quote:[HR][/HR]What's with the talk about stick, doesnt all GTI VR6s COME with stick?!
Nope, they come in auto too chum!
[HR][/HR]​
no way!!!! i'm talking bout the MK3s , no way!!!!!
Discussion Starter · #10 ·
Re: found a 97vr6 gti i like. anything to look out for? (kevinvr6)
Thanks for the tips! especially about the ignition and cable shifter!
By the way, it's a manual.
dave.....
Go for it Dave, you'll have yourself a solid carhttp://****************.com/smile/emthup.gif
quote:[HR][/HR]Nope, they come in auto too chum!
[HR][/HR]​
GTI VR6 are only available with manual!
..the 2.0L was available with auto
[Modified by SuperStar, 6:48 PM 2-12-2002]
1 - 11 of 11 Posts
