1 - 10 of 10 Posts
We have a 2009 SEL and four warning lights came on a few days ago, then turned off, now on again. We had pouring rains in the Bay Area so I thought that affected it. What should I check?
A+
What do you mean by brake warning lights? the ABS light or TRACS light?
If they came on during braking while raining, good chance your tires are towards the end of their life and the car picked up a hydroplaning condition you did not realize. If so, that was likely the traction control light that came on.
same problem and now car is completely dead
those same 4 lights came on in my 2009 Routan SE a few days ago but the car seemed to be running fine and I hadn't had a chance to bring it to be repaired. came out this morning and the thing is completely dead - couldn't even get the door to unlock using the key fob. Did you ever figure out what was causing your lights to come on? Have you had any problems since?
Those 4 lights came on in our 2009 SE and it was a faulty ABS control module. It was about $380 to replace it at the dealer. We did not get it fixed for about 5 months after they diagnosed it. Eventually the dash lights went off, but the ABS and traction control did not work. We never had the issue you describe. Sounds like a bad battery or a faulty ground connection.
Check your battery cable terminals
I had problems like this with my 2009 Routan and it turned out that the battery cable terminals were almost completely corroded through. $50 fixed the problem, my mechanic replaced them with heavy duty ones.
1 - 10 of 10 Posts
