Here's a little how to. I'm sure for most it's an easy job but I figured I'd document it anyway.
My stock instrument cluster.
The first step is to remove your steering wheel for easy access.
Next up is removing the switches. Pull these from the rear forward and they snap right out. Just be gentle.
The switches remove easily by pulling away the black retaining tabs on each switch. Nice color coordinating! Thanks VW!
Next task, removing the four screws that hold on the front dash cluster cover. There is one screw in each corner. Pretty easy to find.
Once that panel's out you remove the two screws that hold in the instrument cluster (one on each side). After that, you will need to remove the speedometer cable. This was a pain in the rear on my car. I had barely enough room to get two fingers in there from under the dash. To remove the cable you have to squeeze the ende to unlock it (see later pic). Next up is unplugging both sides of the cluster in order to remove it.
Here's my stock cluster. Notice that the circuit board looks the same for both. However, upon closer inspection you will see that (near the top bulb area) that a capacitor (?) is in a different location. This is believed to operate the digital clock. So, if you want the clock working make sure you use the old circuit board.
The image above is the tach cluster from a 91 Fox. My car is a 90.
Please note, you cannot re-use your clock cluster lense panel due to the hole for clock setting so make sure the donor car has a nice panel. The circuit boards are the same so use the best one. Since my car had a much nicer circuit board I decided to keep mine and tape off the clock connections. Be careful when removing the circuit board. There are a few plugs that connect to the back of the center panel. I broke one pin unplugging mine. Be gentle when removing the board. It's easier if you unplug by gently lifting on the board from bottom to top. Avoid trying to remove the board from side to side.
All done! Clean and ready to install.
Looking nice. Installation is the reverse of the removal. No special tricks. The speedo cable is easier to install than remove.
The final product! It works! Whoo hoo! Looking sweet.
My final thoughts. Farily easy job removing the cluster. The pain was the speedo cable. Mine had some foam holding it on. The lack of space for your hand makes it a difficult job. I have the cuts to prove it. The circuit board removal probably took the most time. Like I said, be careful when removing it. The frustrating part of this experience was that A. The factory digital clock that came with the tach cluster doesn't work (they usually don't but no biggie, I have a radio clock), and B. After all was said and done my speedo light is out now!
I used my original bulb and my circuit board so I have no idea why it doesn't work! Arrgh! This means I have to take it apart again! So, please test your lights before final assembly!
Anyone notice the tach assembly error? Either the donor car had this tach installed or VW had a backwards tech. Can you spot wehat I am talking about?
Enjoy!
UPDATE!!!!
I removed my cluster again to swap the clock circuit board for the tach one. Now the digital clock from the tach cluster works! Here's a pic to show you the differing of placement for some jump wires.
By the way, it's too dang hot in Florida! Today is December 3rd and it was over 100 degrees inside my car when I began pulling the cluster. When is Fall coming???!!!
Modified by Beetleguru at 11:08 PM 12-3-2006
Enjoy!
UPDATE!!!!
