South Bend / DXD Racing Clutch & Flywheel Kits
DXD clutches are developed and tested across many different friction products, pressure plate loads and flywheel designs with one goal in mind, to create clutch systems not only with perfect balance and symmetry but also to perfectly complement engine modifications without compromise in reliability, drivability or enjoyment.
Each clutch system is specially matched to specific driving styles, uses and power levels to insure the needs of each client are accomplished. Often times, a compromise between drivability and pedal feel must be made to achieve power handling. If you are drag racing you will have different requirements for clutch operation than someone who wishes to participate in daily spirited driving or endurance racing. One clutch certainly does not fit all and APR has done the homework for you to recommend a clutch system that meets your specific goals.
Each DXD Racing clutch is offered in either a Daily, Endurance or Drag configuration to accomplish the power handling of each of APR’s engine performance Stages specifically to the uses of the driver.
Click HERE for 5 speed (02J) clutch kits
Click HERE for 6 speed (02M) clutch kits
Use coupon code "SBCFS1" during checkout to receive FREE SHIPPING discount
:beer:
