Front end service position?
12K views 4 replies 3 participants last post by  rhcp4life
#1 ·
Does anyone know the size of the bolts used to put the front end in service position? I need to replace my valve cover gasket. Removing the intake manifold requires this .
Thanks!
#3 ·
For the lock-carrier swing:
- Remove front blinkers, and open 10mm bolts under the blinkers.
- Remove 3 torx screws inside the fender, right in front of front wheel
- Remove 2 screws and the rubber dampers on top of the lockcarrier
- Remove 3 torx screws just in front of the hood locker
- Remove all bolts from the belly pan (i dont have it, cant recall how it was attached)
- Remove the hoodlockers openign latch (the plastic T that slides out)
Slide the bumper cover off
- Remove the actual metallic bumper
- remove the plastic thingies under the headlights. 1x 10mm and 2x torx.
- unbolt the lockcarrier-fender connecting peace of metal (under those plastic thingies) 10mm bolt
- unbolt the torx on top of the fenders, that hold the lockcarrier.
- Unbolt the hood lock (3x 10mm) and remove the opening wire
- Drain the coolant system. Remove the upper water hose from the engine, and the lower water hose from engine.
- remove the powerstearing oilcooler + outside temp sensor
- Remove the plastic cover from the powerstearing fluid reservoir -> Check wires that goes to lockcarrier and open them.
- Remove the gray 3pin connector from the radiator.
- Remove drivers side light wires
- Now unbolt the 7 torx that holds the lockcarrier on the frame, once youve removed these, you can swing the drivers side to the passenger side like in soundguyob's picture...
http://i50.photobucket.com/albums/f319/soundguybob/TimingBelt001.jpg
Thats the basics, there might be something that i forgotted, but you should easily figure out what needs to be removed / opened, and what doesent...
