Re: Front mount V.S. Charge cooler (Fast_bunny)
quote:[HR][/HR]Actually you are incorrect in saying that air/air is more efficient. The reason why is that the transfer of heat from water to aluminum is 14 times greater the air to aluminum. There fore you can pull the heat out of the aluminum core faster, which in turn cause it to be a lot cooler. When the aluminum is a lot cooler that the air there is a better heat transfer.[HR][/HR]
Granted, if this were on a boat and cool water was available all the time, this would hold true. But a C is not a boat (even if it feels that way sometimes down here in the rain)
There are many heat gain/loss issues involved here (these are simplified calculations). The sizes of frontal area, and velocity of air drastically change the base formulas. But for normal <100MPH driving assuming the same frontal cooling areas, they are close.
Assumptions:
Ambient Air: 100deg F (Florida - hot day)
Altitude: Sea Level
G60 Efficiency: 75% (not exactly sure about this – but does not change comparison much)
Compression: 15 PSI
Air-Air IC Efficiency: 80%
Air-Water IC Efficiency: 90% (does not matter as much, as the radiator is what kills this energy transfer)
Water-Air Radiator Efficiency: 60%
ICE Box Efficiency: 90%
Air-Air cooling
1. Air to G60: 100F
2. Air leaving G60: 266F (see
http://www.3si.org/member-home/jlucius/2-turbotemp.htm for nice calculator)
3. Metal pipe heat gain: 20F (now 286F)
4. IC cooling outlet temp: (286-.8*(286-100))= 137F
5. Metal pipe heat gain: 20F
6. TB inlet: About 157F
Air-Water-Air cooling (ambient air)
1. Air to G60: 100F
3. Metal pipe heat gain: 10F (now 276F) – much shorter pipe!
4.Air-Water IC outlet temp
1.Water temp coming from radiator: (276-.6*(276-100)) = 170F
2.Air-Water IC outlet: (276-.90*(276-170)) = 180F
5.Metal pipe heat gain: 10F – short pipe!
6.TB inlet: About 190F
Air-Water-Air cooling (ice setup for short-term racing)
1. Air to G60: 100F
7.Air-Water IC outlet temp
1.Water temp coming from ice box: (276-.9*(276-32)) = 56F
2.Air-Water IC outlet: (276-.9*(276-56)) = 78F
8.Metal pipe heat gain: 10F – short pipe!
9.TB inlet: About 88F – 12F BELOW ambient air temp!
I like the Air to Air best. It is more efficient due to no compound heat exchangers. It is simple as there are no pumps involved (or to fail, power, etc.).
But, where to put the charger without lots of piping, blocking the radiator and A/C condenser coils, or cutting up the bumper? Relocating the headlights was VW's answer, placing the I/C in the battery compartment. This works, but looks weird. Removing the A/C is not an option here.
Either way I do it, I will have cooler air than the stock IC, or an oil cooler that never lets the oil above the thermostatic value
