1 - 4 of 4 Posts
Re: Front Seat removal... (jetta_grrl)
There is a bolt at the front near the slider lever that you have to remove. There is also a couple of plastic covers at the rear of the seat slider rails that you have to remove as well. Once you have done that simply lift the slider lever and slide the seats all the way back. They will come out of the slider rail, tilt the seat back, and carefully pull it out of the car. Hope this helps!
Passatrcr
Re: Front Seat removal... (passatrcr)
quote:[HR][/HR]There is a bolt at the front near the slider lever that you have to remove. There is also a couple of plastic covers at the rear of the seat slider rails that you have to remove as well. Once you have done that simply lift the slider lever and slide the seats all the way back. They will come out of the slider rail, tilt the seat back, and carefully pull it out of the car. Hope this helps!
Passatrcr[HR][/HR]​
ditto that. http://****************.com/smile/emthup.gif
Re: Front Seat removal... (JetTAFLiTe)
If you feel inside the rails, near where the plastic end caps are, you'll feel a tab sticking through. Press it, and the end piece will slide off easily. You'll need a 10mm wrench and a 5mm allen key to remove the bolt at the front of the seat.
1 - 4 of 4 Posts
