Re: Front sway bar good or bad? (late_apex)
Its seems like you know your stuff, but i think your comnfused about something, or some things you think are implied are confusing me, haha. If you add a thicker front sway bar on stock vr6 setup, it will induce understeer. However, if you remove it will not induce oversteer, just wont have as much understeer, or bite at low speeds. although if you have aftermarket suspension, and a rear sway bar, a front sway bar has to be added, unless you drift your vr6 in the turns, which is not encouraged, since it is very unstable, and not predictable. My gti vr6 configuration, i feel should be one of the more nuetral setups available for our heavy front, FWD cars. That again is H&R/Bilstein sports, with 25mm front, 28mm rear sway bar setup, with engine mounts and strut braces to help tighten everything up. Has anyone tried the b-pillar brace that goes on the floor in the back seat? Does it work at all? Thanx sorry for any confusion, i have been studying for finals all day, and its getting me down
Also check out
www.formularpi.com it should be fully up and running soon, and you can check out our formula car we're bulding, we should be very succesful this year
[Modified by GTIVR6RACER4EVER, 7:47 PM 12-1-2001]
[Modified by GTIVR6RACER4EVER, 7:48 PM 12-1-2001]
