1 - 7 of 7 Posts
Hi guys, i just got this car on the road early this week and im already frustrated here..
at idle and crusing down the road its got a spudder/miss, like a cylinder dropping out,. i can feel it bog the motor down.
when i get on it, it clears out and runs decent.
its got new cap,rotor,plugs,wires, i fixed a few vacuum leaks, fixed the distributor ground, etc..
Seems like its running rich too and is using a ton of gas.
I tired adjusting the CO mixture and i got it as close as i could on the dwell meter but it didnt seem to make a difference.
any ideas on getting this thing to run better??
Thanks for all your help!
Re: Frustrating rough/miss problem 83 Gti can anyone help me out? (DeathsHead1979)
Same thing happened to me--it was a lousy fuel injector. replaced it and all the injector seals and now runs sweet!
--jd
Discussion Starter · #6 ·
Re: Frustrating rough/miss problem 83 Gti can anyone help me out? (Big CADDY)
Thanks guys, i have injector seals and inserts on the way, i will check timing and clean out the warm up regulater too...
anyone have any advice on cleaning out my injectors??
Thanks again for all your help!
People have tried to clena their injectors. IMHO I don't think it can be done. If they are clogged, new ones or professionally cleaned is the only way to go. Some VW dealers have a piece of Bosch equipment that cleans the injectors. New ones are about $40. Sounds like only one of them are clogged. Finding out which one is the hard part.
--jeff dunning
1 - 7 of 7 Posts
