For sale is my 2008 Volkswagen R32. Current mileage is 92,477. I am the second owner and have the clean title in hand. I purchased the vehicle in November of 2008 with just over 3,000 miles on it. It subsequently spent the majority of its’ life in southwest Florida, and is completely rust free. Less than 10,000 miles ago all of the below listed parts were installed. The initial intention was simply to refresh every bushing in the car, as they were all factory at the time, however, in my pursuit of the optimal solution, most of the bushings and parts were upgraded to a higher quality version focused on handling performance and improvement of feel. The end result took what was already an incredible driver’s car, and made it even better.
I have every service record from the last 13 years of ownership. Service was always performed by VW dealerships, and all parts listed below were installed by a dealership. All receipts for parts are present, as are records of installation. The vehicle has never been in an accident and has just had preventative maintenance done, including the water pump and associated cooling system flush/part replacement of prone-to-fail parts.
Mod List:
Please feel free to reach out with any questions, comments, offers, or clarifications. I will be more than happy to facilitate shipping, if that is desired. I will be quickest to respond via email, but will check this post daily! My email is as follows: [email protected]
Many thanks to those that took the time to read the post, and for any interest. I look forward to any interaction I have with you all.
Cheers!
Mod List:
- Suspension:
- SuperPro Forged Alum Front Lower Control Arms
- Includes Bushings and Rear brackets
- SuperPro Roll Center Adjusting Ball Joints
- Whiteline HD Front Sway Bar Endlink
- OEM Front Inner Tie Rods
- OEM Front Outer Tie Rod Ends
- 034 Motorsport HD Front Upper Strut Mounts
- 034 Motorsport Rear Trailing Arm Spherical Bearing Kit
- 034 Motorsport Rear Upper Adjustable Control Arms
- 034 Motorsport Rear Adjustable Sway Bar Endlinks
- SuperPro Rear, Lower Front Control Arm Bushings
- SuperPro Rear, Lower Rear Control Arms Bushings
- Meyle Rear Lower Control Arms
- Sachs Rear Strut Mounts
- Bilstein PSS10 Coilovers
- Freshly rebuilt by Bilstein in California with upgraded Porsche GT3 internal valving
- Not currently installed on the car, but included with sale.
- H&R Sport Sway Bars, Front and Rear
- Driveline:
- 034 Motorsport Street Density Engine Mounts
- 034 Motorsport Billet Dogbone Mount
- Volkswagen Racing Subframe Mount
- HPA Motorsport Gen 2 Haldex Controller w/ Remote
- Milltek Non-Resonated Stainless Steel Cat-back exhaust
- Brakes:
- TyrolSport Brake Caliper Stiffening Kit
- Front Stoptech 345x30mm Slotted Rotors
- Rear Stoptech 310x22mm Slotted Rotors
- Front & Rear EBC Greenstuff pads
- USP Stainless Brake Lines
- Motul RBF600 Fluid
- Chassis:
- TyrolSport Front Subframe Rigid Deadset Collar Kit
- TyrolSport Rear Subframe Deadset Kit
- UNIBrace UB Chassis Stiffening Underbody Brace
- Exterior:
- Full-body Professional Paint Correction
- Two-stage cut/polish to remove imperfections
- Paint thickness reading on every panel
- Full-body Ceramic Paint Sealant
- Glass fully coated with similar ceramic sealant
Cheers!
