I paid $800 to my door step, looking to get rid of everything TOGETHER.
Asking $600 plus shipping.
All parts are for a 12v VR6
All parts were bought from fcp euro
All parts are BRAND NEW IN BOX
I have the following:
Valve stem seals
Valve cover gasket
Oil cooler o ring
Camshaft seals
Crankshaft seal
Freeze Plugs
Head bolt set
Main bearing set
Rod bearing set
Thrust washers
Complete timing chain kit
Oil pump w/ pickup screen
Water pump
Piston ring set x1
Oil pan gasket
Mk4 metal head gasket
Thermostat
Cam locking tool
Valve stem seals
Valve cover gasket
Oil cooler o ring
Camshaft seals
Crankshaft seal
Freeze Plugs
Head bolt set
Main bearing set
Rod bearing set
Thrust washers
Water pump
Piston ring set x1
Oil pan gasket
Thermostat
Cam locking tool
