1 - 20 of 30 Posts
These are the left overs, let me know if you see anything you need, make an offer etc. There are some other nick-nacks that were in a cardboard box, not photographed and thus are escaping memory... but you get the idea. Car was running/driving strong but had fuel line leaks. Chopped to provide a 5speed conversion to another car rather than fix and continue driving. Shipping/paypal fees extra, or pickup in Concord, NH.
Before:
After:
AAN/ECU sold. Harness available still $75
Black leather heated front seats $250
Washer reservoir w/ HL pump and some line $20
Steering wheel/airbag $30
Wiper motor w/transmission $20
Aux electric fan $30
Pedal cluster (brake only, no clutch) $10
Starter $20
Ignition modules with bracket $40
PS high pressure line SOLD
Split rear headrests SOLD
Rear seat belt receptacles $5
Generic rubber floor mats $5
Visors $10
Heater box w/recent blower motor, rubber bellows and three flap motors (red, blue and temp) $75
Split fuel rail cover $10
Firewall connector cover SOLD
10 disc changer with silver converter box $20
Steering column switch shroud $10
Rear outer tail lights $30ea
Front marker/turn signals $25ea
Driver headlight, with bulbs, one upper mount broke in storage SOLD
Bose Amp $5
ABS computer SOLD
Airbag module $10
Rear diff vacuum module $5
Accelerometers $5
Cruise control module $5
Sunroof motor $30
MAF to turbo hose $50
Horns $10
Shift boot SOLD
Upper intercooler mount $5
Center dash switches $15
Window motors $40 for the set
Downpipe w/flex joint and O2 sensor $25
Bomb SOLD
Clutch master $10
Serp belt tensioner SOLD
Upper strut bearing plates $20
Brake master cylinder/booster/res SOLD
Front strut housings SOLD
Airbox SOLD
Heater core lines w/sensor, T-fitting had been replaced $20
Metal plenum/wiper motor/lower windshield cover $10
Plastic plenum cover $10
Wiper arms $10
Upper strut plastic covers $5
Front bumper shocks $20
Rear bumper trim, 3 pieces $30
Left front bumper trim $15
Left headlight washer trim SOLD
Hood mount/plenum brackets $5
Fender support brackets $10
C pillar trim pieces $10
Upper stress/tie bar $10
Upper core support and rad support sides SOLD
Lower core support SOLD
PS reservoir w/cap and line $20
Tie rods $5
Interested in a bunch of stuff if ya have it
Clamshell
Rear calipers
Any exhaust pieces you have
Corner lenses
maybe seats
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Headlight washer/ bumper trim
Interested in the drivers side headlight washer trim. Any chance you have the nozzle and the cap that goes with it in working condition?
If you have any of the following, I'd be ready for immediate purchase.
Driver's power window master switch
Passenger side inner tail lamp
Rear headrests
Dome light/sunroof switch console
Thanks!
Interested in :
Driver inner taillight
Nemo passenger mirror
Delta radio (if display is good, everything is functioning and can get code)
Power mirror controls
HVAC controls
Plastic undertray for engine.
1 - 20 of 30 Posts
