ok so im putting this up for sale for a friend of mine who is out of town for the next few weeks but if anyone is interested just pm me and ill be able to show you the truck.
2005 Escalade
42k miles
just professionally detailed
new pads and rotors on all 4 corners less than a month ago
all scheduled maintenance up to date
new tires for the 24" status wheels
stock wheels will also be included in the sale with all season tires that have great tread.
car is driven about a total of 5 miles a day (home -> work -> home)
here are some specs...
2005 Cadillac Escalade ESV Sport Utility Performance & Efficiency Standard Features
Power: 257 kW , 345 HP SAE @ 5,200 rpm; 380 ft lb , 515 Nm @ 4,000 rpm
Fuel economy EPA highway (mpg): 17 and EPA city (mpg): 13
External dimensions: overall length (inches): 221.4, overall width (inches): 79.5, overall height (inches): 75.7, ground clearance (inches): 10.7, wheelbase (inches): 130, front track (inches): 65, rear track (inches): 66 and curb to curb turning circle (feet): 43.1
gross vehicle weight rating (lbs) 7,200, curb weight (lbs) 5,820, gross trailer weight braked (lbs) 7,800 and max payload (lbs) 1,380
Auxiliary oil cooler
Auxiliary transmission coole
5,967 cc 6 liters V 8 front engine with 101.6 mm bore, 92 mm stroke, 10 compression ratio, overhead valve and two valves per cylinder LQ9
Multi-point injection fuel system
31 gallon main premium unleaded fuel tank
Four-wheel ABS
3.73:1 axle ratio
Four disc brakes including four ventilated discs
Electronic traction control via ABS & engine management Immobilizer
Spacesaver steel rim under body spare wheel
Stability control
Wishbone front suspension independent with stabilizer bar and torsion springs , beam rear suspension rigid with stabilizer bar and coil springs
Automatic rear suspension levelling
Body color front and rear bumpers
Driver power heated partial-painted door mirrors with automatic and automatic operation indicator lights , passenger power heated partial-painted door mirrors with automatic indicator lights
Navigation system
Heated seats
Electric foldable mirrors
Front fog lights
Conventional lens Xenon bulb headlights
Heat reflective glass
Luxury trim alloy & leather on gearknob, wood/woodgrain on doors and wood/woodgrain on dashboard
Rear and side platform step
Tinted glass on cabin , privacy tinted glass on rear , privacy tinted glass on side
sorry for this last one i forgot to take an interior pic and locked the truck up and returned the keys...
kbb is between 23.5k and 27k
looking for
$24k/best offer
2005 Escalade
42k miles
Four-wheel ABS
3.73:1 axle ratio
Stability control
Navigation system
Heated seats
Front fog lights
looking for
$24k/best offer
