1 - 4 of 4 Posts
Currently off market: 30+ upgrades, 3 weeks of work, decent amount of cash thrown into her, new look since posted.
1979 Audi 80 Fox GT2871R Eliminator 350hp 1.8t
Update Edit: Under dash master system full installed and driving
In the middle of a bolt in under the dash master cylinder conversion. Leaving it up to the individual to proceed forward or reinstall the oem brake booster system which comes with a custom shortened 1.8t intake manifold (so clears the brake booster). And under dash heater box and fresh air system complete box if you go the oem master cylinder route.
Here's the bnib under dash master cylinder conversion and custom shortened ceramic coated short intake if you ever want to swap back to the oem brake system.
Car was taken down to unibody, respray of undercarriage being rubberized, polyurethane coated fender wells, complete restoration of entire trunk (every nut, washer, hose, gas tank, trunk springs ceramic coated), all suspension components, steering rack system.
New
- Wheel & tires
- Chrome tuner nuts and stud conversion
- Front large x-drilled Wilwood kit
- Rear large x-drilled Mk4 drum to disk conversion
- Full custom e-brake system
All new custom interior,
- Professional made door cards
- Red seats and rear bench
- Mint roof with custom made visors, oh sh*t handles reconditioned
- Professionally redone carpet
- B5 conversion dead pedals with ceramic coated pedals
- Ready to install Retro Sound old school looking radio with bnib JL Audio speakers specifically bought to fit both the center console (already has a radio wired) and door cards.
- Brand new Made In Germany chrome Mk1 handles with color matched inserts
- Custom new A and B pullers
- Floor pan, rear shelf, door cavities, door pockets were cleaned, scuffed and shot in professional grade polyurethane with ~$300 in dead mat (rear shelf, door metal and pan).
Custom this custom that it's basically a Mk4 shoved into an Mk1 Rabbit.
1.8t has custom made aluminum front mounted radiator with custom Spal fans as originally these cars have internally mounted radiators, custom EVOMs 1.8t intake in tig weled plexiglass box, tubular ceramic coated manifold with Garrett GT2871r Elim full ~2.5" downpipe back all enimal coated. FMIC, ceramic coated pipes, 440cc injectors, Unitronic 20 PSI software. Mk3 serpentine belt conversion, custom tig welded under the manifold coolant pipes and coolant tank. Entire gas tank, 100% nylon stainless woven gas lines, ~800hp pump and billet filter, fittings all the way the rail all redone...basically redid everything.
The paint is....looks fantastic from ~10', which was next to do after putting in Vintage Air AC System (not included) (https://www.ebay.com/itm/264256267253)
There's more, will post at some time. Car is always garaged here in Phoenix, Arizona. $15k firm no trades. Blake 602-487-38threeeight (if you want to talk text first as too many robo callers so won't answer, text is fine too).
Discussion Starter #2
Want to change the look?
Color matched oem wheels & white wall tires:
Brand new / oem restored front Fox brake kit (Wilwoods are too big for oem rims, this kit simply bolts on). Calipers are shot in professional grade enimal out of a professional grade Italian gun like all the pieces on the car...aka no spray paint).
Along with the German BNIB NOS chrome handles, bnib chrome latches and striker pins, and chrome hydraulic hood lifts
You had something like this and you were complaining about the price of b5 s4 fenders
shipped 2,000+ miles? Lmfao!!!
Discussion Starter #4
1 - 4 of 4 Posts
