Asking price $11,000.
Located in Seattle Washington.
This car is garaged all the time, kept under a thick custom car cover and driven once a year.
PLEASE... serious inquires only!
Here are the details:
• Original owner since 1983 (100,070 miles on her)
• Sunroof, wing side windows as an option
• 5-speed manual trans (10,000 miles on trans since 4.25 ring & pinion install)
• Limited slip differential with “Canadian” 4.25 ring & pinion
• 5th gear replaced to match new ring and pinion
• Quaife Limited Slip Differential
• REDLINE MTL trans fluid
• Techtonics short shift kit (shorter throws between gears)
• Techtonics 1960cc hand built by Collin Gyenes has Audi Connecting Rods (30k on engine)
• 10w40 AMSOIL Synthetic Oil/Filter changed every 5,000 miles
• Oil pan with windage tray/baffles
• Formula 1 Engine Oil cooler with thermo plate and braided hoses
• High volume oil pump
• European N-Grind cam
• Heavy duty tappets and springs
• Neuspeed large throttle body with welded manifold (not an adapter!)
• Techtonics Euro exhaust manifold
• Techtonics Downpipe (NO CAT!)
• Techtonics Euro Exhaust
• Borla Race Muffler
• H&H Racing front lower stress/sway bar
• GMP upper stress bar
• GMP rear stress bar
• H&H Racing rear hollow tubular bar
• Stock rear sway bar
• Neuspeed Koni AutoX Struts and Shocks (adjustable)
• Rabbit Hutch AutoX/Race Springs with LARGE spring perch
• 10" ’88 Scirocco front brakes and calipers with new pads
• 14" Centra Type 1 wheels (this is the first set brought over from Germany and painted black for me!)
• Light weight flywheel and stock clutch
• Linear Power AMP/Alpine deck and six speakers
• MOMO Cobra GTI steering wheel
• HELLA European glass headlights
• Original GTI Floor Mats
• European GOLF Ball Shift Knob
• European GTI distributor
• Jacobs Electronics Plug Wires
• Diesel Side Motor Mount
• Front Poly Motor Mount
• Poly front A-arm busings and rear trailing bushings
• Braided brake lines throughout
• New Front Grill and GTI Badge
• New plastic wheel well arches
• New Rubber Seals throughout
• New felt seal in Sunroof
• New door handles and amour guard door plates
• New tail lights
• New side view mirrors
• OEM GTI Mud flaps on front
• New Timing Belt and valves adjusted at 97k
• New spark plugs, distributor cap,rotor and points
• New Alternator
• New Battery
• New Fuel Filter
• New Clutch Cable
• New windshield washer reservoir and pump
• K&N Air Fliter
• CRIMESTOPPER Alarm system
• Ignition Kill Switch
• Groit's Garage products used throughout
NO AC, NO CAT.
FUEL STABILIZER & "TRICK 101 RACING GAS" IN GAS TANK.
$3,000 strip to bare metal resto in ’97. Clear coat added. All new fender molding and OEM panel striping. Rear hatch painted black vs a decal.
Dash is NOT cracked, faded or torn (car is stored in its own garage).
Extras to go with car...
Complete new OEM brake set for front. Original GTI steering wheel, OEM center console Clock, OEM Golf Ball shift knob, SACHS Sport clutch, OEM Springs.
PLEASE PM ME IF YOU HAVE QUESTIONS!
I will not be selling any parts. Everything goes with this car!
• New tail lights
• New Alternator
• New Battery
• New Fuel Filter
• New Clutch Cable
• K&N Air Fliter
NO AC, NO CAT.
