FS: 96 Getta vr6 $3,000obo
Well here is my pride and joy, Ive been building her and cannot afford to keep it. The problems are the drivers windows needs new regulator, old one broke. all other windows power and work, sunroof works and does not leak, clutch is good has plenty of life in it. the car has just over 118K. The car was in an accident, has been fixed also has had gti front end conversion done. The car drives straight with no problems. frame is straight car has clean title. have recipets from body shop was a minor fender bender. The car will have new inspection and emmissions, The check engine light is on due to the gutted cat and other performance modafications, This does not effect the way the car drives however does effect emissions. the car is sold as is! and if you need emissions either be friends with your mechanic or get a new cat on it. the car does not have ABS. did come stock but with the brake upgrade the abs had to be removed. the paint is in ok condition, needs to be buffed has some chips and scraches in it, the car is 10 years old, however, the car maybe be 10 years old but will pull on most new car out there with 200HP. This car is quick for what it is. Im asking $4,000 OBO The car does not get the best mileage. about 20-23 city highway mix. depends if you want to get on it. This jetta will do 145+ with the chip installed the stock chip will stop you at 130ish. the car will pull to 145 it has been there. The car has been mechanic owned and maintained its whole life. sold between friends for years. it is a great car just time for me to move on. The car comes with plenty of extra's, Stock wheels and tires, Ported throttle body, anything else i can find laying around. for more pictures email me.
I will trade for a mk3 gti vr6 or any mk4, well just let me know what you have vw or not ill accept decent trades as i picked up a mk2 gti and that will be my dub project for the time being.
The Mods:
Engine:--------------------------------------------------
Ported Throttle body great for track day, Makes the car run funny not good for daily driving but will haul off the line.
Coolant bypassed Throttle body
Ported&gutted MAF
K&N cone/short ram intake
Ported&gasget matched intake manifold
No Cat or rear O2 sensor.
OBX 2.5" stainless mandrell bent catback
DimSport Chip, Comes with stock chip installed, Aftermarket chips give 7hp but have to run 93 octane gas
Brembo drilled/slotted rotors with semimetallic pads.
Secondary air injection deleted
High performance motor mount incerts
Exterior:--------------------------------------------------------
M3 fiberglass sideskirts
Wings west front lip
Smoked turns,side markers
AT italia INOX rims with General UPH tires, Brand new have less then 200 miles on them, car also comes with stock BBS wheels and good eagle all season tires
The car has a GTI/GOLF front end conversion on it.
Also has fiberglass strickly foregine turbo fender, has scoop for intake, real scoop and works.
Interior/system:----------------------------------------------------
Balupunkd Head unit
Kenwood componet speakers
Has wires for AMP and system hookup, will handle 2000 watt amp
Autometer vacuum gauge
Sunpro Air/Fuel gauge
Stock seats, drivers bolster has rip starting to form from wear getting into and out of the car.
Racing pedals, Bolted to stock pedals not pin on.
Modified by Jettadude17 at 2:24 PM 1-9-2007
The Mods:
Ported&gutted MAF
Balupunkd Head unit
