please read everything, the car has a blown transmission, I'm including a spare with the sale...
1997 2.0 jetta 5 speed, 156k
the engine sounds like it has 156k but I've been using 10w40 synth, no issues, no leaks.
Good:
no codes at all. cel bulb works, no codes. the car is current on CT emissions.
new belts, timing, serp, acc.
new hubs and bearings.
new oil cooler seal, new front main seal. new oil pan gasket. new valve cover gasket, new upper coolant flange, G12 coolant,
new waterpump and housing. old style (better) belt tensioner
has full magnaflow 2.25 exhaust. VR cat.
brakes (new pads).
rebuilt shifter.
lots of maintenance work taken care of.
has rokkor coils, all new bushings. tie rods, ball joints, control arms have r32/poly.
newer clutch with less than 10 thousand miles on it, eurospec flywheel.
the car is satin green and flat black
has tan passat leather front and rear seats, dark grey suede headliner, 2 tone door pockets, lots of little interior mods like this..
the rockers do not have any rust, there is zero (NO) strut tower rust, there are NO rust issues with the floors.. anything questionable was taken care of.
shaved rear decklid.
heated seats, lots more I'm not thinking of at the moment.
Bad:
one or more differential bolts broke.
I have a spare trans to go with the sale that needs a reverse gear installed.
$1200 as is firm.
located in CT 06606
here it is needing a replacement trans...
Good:
brakes (new pads).
rebuilt shifter.
Bad:
$1200 as is firm.
located in CT 06606
