1 - 3 of 3 Posts
C2 AMS VR6 S/C kit w/ Vortech V3, FIts 92-99 12V
SOLD SOLD SOLD SOLD SOLD SOLD
Like new charger purchased direct from Vortech 2500 miles ago. Has had one oil change using the vortech synthetic oil. The V3 does not share engine oil it uses its own oil contained within the charger case. This makes for a cleaner install without any oil return or feed lines. Smoothed A/C pulley (not pictured) will be shipped with bearing with 2500 miles on it.
Price Does Not include Software. Software can also be provided at a discount for this kit. Available for any OBD1 and OBD2. Also OBD2 users running C2 or United software will need a 95MM MAF housing when using the 30# or 42# injectors and software. OBD1 30# with uses the original MAF OBD1 36# must also use 95MM MAF housing. Must reuse your MAF element (not provided).
Air filter is shorter than image shown in last photo. Also has a k&n dry wrap along with a alloy water shield.
AMS Carb# on the charger, passed emissions testing in California.
Fits all Corrado VR6, MK3 Golf Jetta and 93-97 Passat.
Buyer pays shipping. Thanks for looking. Made additional 80 WHP and 65 WTQ.
Kit content list:
Vortech V3 supercharger w/ 3.12" 10 psi pulley
C2 Bracket kit (powder coated black)
VMS support bracket (powder coated black ( no drilling head for extra support)
Vortech Idler pulley new bearings at install
S/C outlet to TB pipe OBD1 ( 3 ports ISV, V/C Vent threaded, and DV)
C2 S/C outlet to TB pipe OBD2 ( 1 port for DV)
C2 S/C Maf to Inlet pipe ( 1 port for DV)
Machined A/C Pulley new bearing at install
K&N Filter & Dry wrap sock
Alloy air filter splash guard
Silicone couplers, clamps and hardware.
Bosch 710N DV
6-30# bosch inj Rebuilt at install by witchhunter
New 7 rib single side belt for A/C and P/S
New AMS Belt guard
1 - 3 of 3 Posts
