1 - 11 of 11 Posts
This will fit Jettas equipped with a TSI.
Selling a complete turbo kit off of my car, this kit is proven as you can see from the dyno charts and videos below. The kit is a ton of fun on the street as I daily drive the car. I am only selling to take a gamble with a bigger setup.
What the kit includes:
1. Cast Stainless Steel Manifold T3 Flanged
2. Precision 5530 Ball Bearing Turbo. "E" compressor cover and .63 A/R hot side
3. Internal wastegate setup with 1 bar actuator (the manifold and wastegate with be bolted on and setup already)
4. Stainless Steel v-band downpipe with extra 02 port that can be blocked or used for a wideband.
5. 2.5" turbo outlet piping from turbo to intercooler
6. Synapse diverter valve and diverter relocation
7. BSH throttle body pipe
8. 3.5 inch intake pipe
9. All hardware and clamps
10. Coolant lines
11. Oil lines
Optional Equipment:
1. Eurojet stock location FMIC
What you need:
1. Tune (my dynos are all using Unitronic software)
2. Exhaust manifold gasket
3. Stage one intake or big filter like mine I can give you the part #
4. A few misc. items such as vacuum line and boost tap (items most people have already)
5. Fueling system and built motor for over 425hp at the crank. (I am using IE drop in rods and the Unitronic HO fueling system)
Photos are exactly what you get:
Factory Fueling:
Unitronic Fuel System:
If you have any questions feel free to ask!
There is no need for a TOP or TB pipe with this kit they are included, meth bung on intake will have a plug in it. To hook up breather without a catch can you would hook up the rear breather on the valve cover to the AN port where my catch can is hooked up.
Price is:
$3000 kit with intercooler
$2750 kit w/o intercooler
IC is now available alone at $450 will need aluminum coupler which I can help supply (not needed with turbo kit)
Buyer pays shipping or local pickup/meet up if near by
Discussion Starter #2
not sure if I made this clear but this is the exact kit that these dynos are made with. Selling only because I am switching to a setup that will be more of a race car instead of DD and be bigger.
I am happy to answer all questions on it.
Discussion Starter #3
Worth every penny and more. My graph is as smooth as an NA car, no dips no jumps. Clean power always from start to redline. Plus my mpg jumped about 3-4mpg with the HO fueling system.
Got more parts in and I'm getting excited for the new build for those who want an insanely smooth big turbo car I am droping the price. I want to see someone else enjoy it as much as I do everyday. Kit is coming off the car next Saturday $3500 full kit - $3300 no IC :D
Discussion Starter #11
Some one has to want to go fast for less, but just need to get rid of it so rock bottom number it will not go lower -
New price, Firm -
$3000 Kit as described.
$2750 Kit no intercooler.
1 - 11 of 11 Posts
