A) Custom made intercooler spray bars: $125 each plus shipping: Many ways to operate them, your call you'll receive details just ask
B) This is a lightened, sandblasted and coated accessory bracket with ceramic coated hardware and p/s brace. Note the lack of all the criss cross boxes and odd chambers these come with, in addition the entire viscous fan assembly has been removed for EFK conversions: $100
C) This kit gets rid of all the busyness on the accessories side of the motor, loses weight and produces more space in the engine bay while lowering the center of gravity.
You go from this:
To this:
This is a custom one of a kind accessory bracket designed to work with either 058's or 06A's (lmk if 058), a brand new alternator shipped in from another country, a real authentic made in Germany p/s pump with Unorthodox Racing aluminum leight weight pulley with brand new Audi hardware. Bracket and pully come with ceramic/enimal coated bolts. Bad news I tossed the required serpentine belt in a box with other belts and got mixed up, good news is I believe I have 2 belts lying around and would throw both in as pretty sure one is it (if not you wrap a string around the pullies, measure the length and walk into any auto shop and get a 5 rib serp 15"/20"/25" long belt for ~$9).
You'll toss your long serp belt, pesky tensioner system, accessories bracket with hardware, alternator, pullies, fan clutch and p/s pump and bolt this on. (Efk kit was sold, if you haven't converted to an electric fan easy to do and can walk you through it).
What hardware is like:
$350
Which is a far bigger & unique upgrade then cams or a custom intake manifold....not to mention you'll recoup any costs selling off the pieces your remove. There is a considerable amount of time, energy & money into this.
Brand new Unorthodox billet pulley upgrade to add to kit +$70 (will be coated purple free of charge upon request)
Please Note For 06A AC Users: You will mount your compressor on the passenger side using an 058 AC bracket (which is far cleaner, simpler and lowers the cars center of gravity). My 06A is using this system.
D) Custom aluminum coolant reservoir: Can mount against false fire wall in ~oem location, also designed to bolt directly to an 06A block (brackets included) if you have an alternator drop down kit. Bottom port is 12AN which reflects OEM coolant diameter, side port is 6AN which reflects OEM coolant diameter. Cap is proper BAR pressure rating for 1.8ts, over flow works, coolant window, etc. $130
Or sideways
You go from this:
To this:
$350
Or sideways
