STILL AVAILABLE
$75 shipped to the lower 48
Modified by rabbitarmy at 2:26 PM 2-7-2008
Quote » |
Tap into hidden horsepower with a new Euro Sport crank underdrive pulley! CNC machined from 6061 aluminum, these crank pulley kits underdrive your accessories by 23% on 4 cylinder engines and 13% on VR6 engines. This, in turn, decreases engine drag, unleashing power that you never knew you had. And since the Euro Sport crank underdrive pulleys are lighter than the OEM crank pulleys, you'll benefit from the weight reduction of rotating mass; resulting in a more responsive engine.As an example, compare the Euro Sport Mk3 8v pulley at 7.6 ounces to the OEM Mk3 8v pulley at 3 lbs. and 4 ounces. Euro Sport crank underdrive pulleys come in a blue anodized finish. |
