40mm Empi HPMX Carb setup
$375, firm.
Or trade for GOOD 1.8 8v CIS motor or 2.0 ABA motor, in those cases local only. Not interested in ANY other trades.
(2) 40mm 2bbl HPMXs with Type-4 intake manifolds, air filters, gaskets, studs, bolts, etc.
Setup:
28mm venturi
52 idle jets
115 main jets
200 air jets
F-11 emulsion
These are clones of the Weber IDF, and use the genuine jets and rebuild kits.
Hex bar linkage is not included.
Intake manifolds are for a Type 4 motor.
You get the added value of my having TIG welded vacuum ports onto both manifolds, so you can run your factory brake booster.
Also included are the following jets:
(4) 55 idle jets
(4) 60 idle jets
(4) 120 main jets
(4) 125 main jets
(4) 130 main jets
(4) 180 air correction jets
Serious interest only.
Shipping extra, shipped insured.
Buyer has all responsibility to for determining proper fitment, proper jetting and tuning, and proper application of the carbs. I take no responbility for anything beyond a safe delivery.
Again, carb linkages and heim joints not included. Buy a CB hexbar or CSP linkage.
Linkages shown in pictures not included
$375, firm.
Setup:
28mm venturi
52 idle jets
115 main jets
200 air jets
F-11 emulsion
(4) 55 idle jets
(4) 60 idle jets
(4) 120 main jets
(4) 125 main jets
(4) 130 main jets
